HF spark gap adjustment needs to be done, it's inside the machine, front of bottom circuit board.
Testimonial: "thanks for your help Larry i checked the HF it is arcing i did adjust it but no help barley will cut piece of tin takes forever to do that The HF arc stops arcing when you try to cut do not no if that normal"
SOURCE: I have a cheap chinese plasmam cutter a giant cut
Internal componet failure, return the machine for repair. Who did you purchase it from?
the HF is arking goes out when trying to cut act like it not getting enought amps
green light stays on red light never comes on
it was cutting good then went back to cut something else would not cut air pressure 70psi thanks
tried another torch did not help
