Elite Home Electronic Personal Bathroom Scale Clear Logo
J
Jolanta Wysocka Posted on Feb 22, 2018
How to change the battery in bathroom scale?
Could you please explain how to change battery in Bathroom Scale (SilverCrest)? I have looked into instruction which was provided with the item but it is completely useless. I can open the battery compartment, I can see the battery but I can't remove the battery so I can't change it.
How to calibrate Silvercrest sbf76
notify silvercrest customer service
My Taylor 5778F bathroom scale read outs are difficult to read. For example an eight requiring 7 little bars to complete has but five. Is it reparable
Try a new battery. If that doesn't fix it, return it to Taylor under Warranty.
Digital Scales - Taylor USA
www.taylorusa.com > collections > digital-scales
Digital Bathroom Scale with Natural Bamboo Platform. Shop Now. Digital Glass Bathroom Scale with Backlit LCD Display. Shop Now ...
1helpful
Propert bathroom scales does not work after changing battery. keep getting Err message
Check that the battery is in the correct way. Reset the machine after you check battery.
How do I remove the batteries to replace them?
Hello, Joanne -
WeighMax manufactures more than one model of bathroom scale. See:
http://www.weighmax.com/products/bathroom-scales-1.html
Not all the WeighMax bathroom scales take the same kind of battery. If your scale is one of them listed on the web page cited above, click or tap on the link for the information on the scale and look for the information on Power to find out the kind of batteries needed.
I do not find any instructions for where to find the battery compartment on any WeighMax bathroom scale. Therefore, I suggest you contact WeighMax Technical Support and ask. You will probably need to provide the model number of your bathroom scale. This is the link to the WeighMax Contact Us web page:
http://www.weighmax.com/contacts
Best wishes.
12helpful
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
10helpful
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
1helpful
Conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Top Elite Health & Beauty Experts
Rob Hill
Rob Hill
jws1013
Paul Carew
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
