I can not get my fireplace to light the ignator may be shot, 2020 lp ardent signature model can you help, I may need a instruction manual as I bought it used and did not get one
Added all new copper, values and I think it's the ignator
I have a Monarch fireplace (LP). Each year I have to take a can of computer cleaner "air" and spray out the oxygen sensor located near the pilot light. If dust or a spider blocks this oxygen sensor, the unit will NOT turn on. The pilot lights but the rest won't start. You can also contact your local gas company and ask where yours is located on your unit.
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
