How to take display not working cooling fan and procecer but motherbord working hardisc and dvd rom all are working on the power
Main processor [CPU] do not detect all the other peripherals. Any voltage loss can cause this. Your PCs motherboard need to be checked. It will be best to contact the authorized service centre for Sony; in this case. This is not a user detectable fault.
SOURCE: Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
SOURCE: Sony Vaio PCG-FRV25 Cooling Fan Issue?
I was going to suggest overheating before I read your own diagnosis; Yes, sound like the fan, but you can check by opening up and watching it. Or install temperature monitoring software such as Speefan;
If it is the fan it may well be that there is only one possible replacement - officially. But it is usually possible to cannibalize something cheaper to suit your purpose!
SOURCE: sony pcg k45
Put the cd in and restart. If it doesn't give you a message to press "x" to boot from cd, then you need to chage the boot order in the BIOS.
To get into the BIOS, restart and press del or F2 (it might say something on the screen like press del to enter setup) that is the BIOS.
Change the boot order to CD first.
Hi mohamed jakkath, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How long have you had it ie,did you get it this way?
Have you ever cleaned it internally?
Have you tested it with an external display?
What have you tried to get it working?
