Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
A
Andrew Boardley Posted on Nov 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony KDL-52W4100 standby light blinks 13 times after being switched on. The lower part of the screen briefly lights up then the unit standby light starts flashing
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Nov 29, 2014
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987209
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
5 Related Answers
Anonymous
  • 201 Answers
  • Posted on Apr 27, 2009
SOURCE: Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
electroman
  • 1039 Answers
  • Posted on Apr 26, 2009
SOURCE: 13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Anonymous
  • 201 Answers
  • Posted on Apr 29, 2009
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Anonymous
  • 106 Answers
  • Posted on Jun 16, 2009
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Sony tv kdl52w4100; 13 blinking red lights
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Sony KDL-46z4100 standby light blinking 12 time with few seconds gap continiously
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Sony tv screen has no picture
Watch the red light and or power light when this happens, if there is a specific number of blinks and then a pause that is a error code.
8helpful
Sony kdl-40w3000 does not turn on. Standby light blinks 13 times. What is the problem
sony kdl-40w3000 does not turn on. Standby light keep blinking. What is the problem
4helpful
3answers
13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
4helpful
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
