are the batt connection clean and tite--test fuses with a lite------inspect wiring for flaws specially in headlite area-----ignition switch or solenoid relay cud hav failed
I took the battries and cartridge out and started all over. The cart. was stuck. That must have been the problem because when I put everything back, it worked. That you for responing. Arlene Gerrity
did you check remote like battry, loose nothing is deposited near battry contact etc.
if it is getting on from front board and not from remote then fault is due to remote.
but if does not start from front also then problem is inside tv.
like power supply or horizontal section failure.
please do not forget to check plug & socket.
In order to narrow down the issue, I suggest you the following steps.
1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera.
If this doesn't fix the issue, Than....
2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain.
If this doesn't work.
3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not.
This is the way to narrow down the issue.
Thanks you.
