There were times that I was able to turn the tv on after pressing the power button on the remote control many times. When I turned the tv off, and then on in a few minutes, the tv would still turn on. But when I left the tv off for hours, the tv would not turn on again. Usually the red light flashes 7 times, but there was one occasion, it flashed for 6 times repeatedly.
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the
same thing when you turn on the power button on the remote when the tv
turns on you hear a click then the red light flashes about 5 to 6 times
then the tv comes on. on the remote there should be two buttons on top
of the remote one says power and the other one says system hit the
power button to turn on the tv when you hear the click and see the red
light flashing then hit the system button which will turn off the tv
then hit the power button again and it will turn the tv on without the
red light flashing it should work
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: My Sony TV: FD Trinitron
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: Sony trinitron WEGA won't turn on and standby
Unfortunately, what you're describing is a repair issue. You won't be
able to address the problem with troubleshooting. There is a part
inside the TV that needs to be replaced. If you're under warranty,
this will cost you nothing. If you're not under warranty the cost
will likely be a minimum of $200 parts and labor. However, be warned
Visit the link below so you can talk to Sony either on the phone or via online chat for your full range of options.
http://esupport.sony.com/US/perl/support-contacts.pl?
