I recently reset the breaker for the oven at the main panel and when I flipped it back on, the ovens no longer work. The clock works, but the ovens will not heat, nor will the lights turn on. What can I do?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Double checked - the clock has been set for manual cooking. I flipped the breaker as I was wiring a new microwave in the kitchen (different circuit, just wanted to be safe). What surprises me is the oven lights do not work either, but the clock works. Is there anything else it might be?
I'm still convinced the problem is related to the timer/relay in some way but I can't suggest any DIY problem busting solutions, sorry.
SOURCE: viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
SOURCE: double oven, at least 10
Is it the Viking VEDO273 ? I can track them down for you. Most likely it is the control unit for that front plate, it's pretty rare for the panels themselves to go bad, but there is no way to tell without trying. The place I will recommend for parts (if we can find them) will definitely allow you to return the part if it ends up being the panel and not the control, or vice-versa...
Thanks
Tim
My Viking microwaveModel VM0S200 was working untill last night. This morning it stopped working. The clock and the timer works, even the light turn on, but the table does not rotate, and the heat and the fan are not working. I will appreciate any help I canget.
