SOURCE: 56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
SOURCE: my rca d61130 projection tv has red/pink faint lines
It sounds as thought he convergance needs to be adjusted. You will need to push the auto adjust button or go into the menu and do a manuel adjust. Any adjusting instructions should be listed in your Operator Manuel. If you require more assistance in this matter, please write back. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
SOURCE: RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
