We have a kitchenAid Super BA side by side refrigerator, and the water dispenser now has a significant delay from the time you push the fill lever to the time it actually starts to fill, ice machine and ice fill work fine. It started with just a second or 2 delay, now up to 15 seconds
SOURCE: Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
SOURCE: KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
This refrigerator has other design problems, which Kitchenaid refuses to address...Does your ice maker spill ice all over the inside of your freezer because of the gap at the back of the bin? Constantly hearing the clitter clatter of falling ice inside the freezer and having to pull everything out to remove all the pieces from the bottom of the freezer became such a nuisance my husband finally duct taped a piece a plastic to the bin to fill the gap. I won't buy another Kitchenaid anything because they wouldn't fix the problem.
SOURCE: Kitchenaid refrigerator water dispenser not working
you may need to replace the water inlet valve. it is a dual valve, one side for water and one side for ice. part #2304833. see the attached breakdown #10. perhaps this will help.
SOURCE: Ice dispenser flap will not close tight and the
Sometimes the door hinge tabs can break and will cause the door to stay open. The door assembly will need to be replaced. Here is a link to the part.
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
