I have a 7 inch tablet modelrct627 2w23. when I turn it on I then put in my password. I then go to settings. I set settings but the tablet will not go on line.what am I doing wrong
By not being able to retrieve it, that is how it's secured. Will it let you reset a password? If not take it back to factory settings . If you have data you want to save back it up on a PC . Do you have some kind of cloud available on the device. That you can put your data to be saved in?
First of all, you must have the password which is set for your home WIFI. You can't do anything without it. Assuming you got the password, Go to tablet's Settings, turn on WIFI. When your WIFI router is displayed in the list, select it and you will be prompted for the password. Enter the password and click Connect. When you see Connected, it's done.
When entering the password there is a tick box that allows you to save the settings and connect whenever this wifi available, check the settings from the password page!
The password is set up by you when new, from new no passwords are set! You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
it's easy if you register your tablet with your mail account... then connect with your wifi and enter your mail password then it will be open.. or according to you it's newly perches then go to service center.....
start your tablet when network connection is available then it's auto connect and go to the forget password and you can login your registered id then it's open ....
Tap 'Applications' to open the main apps menu and then tap 'Settings'. You may need to sweep with your finger to a new screen of shortcut icons before you can see 'Settings'. Tap 'Location and security' then tap 'Set screen lock'. Next tap 'PIN' to set up a pin number for the lock screen. here you can set and reset your password
