Question about Maytag Dryers
I have checked fuse box. Looked on line, but I don't know which avenue to look further. Could it be tumbler related? The shudder/sound and int. light indicates power is fine? Please advise, thanks!
If thermal fuse ok you may have a problem with your interface board. Check thermal cut out, door switch and thermal fuse before suspecting board. Obviously need model to give you more accurate info.
Posted on Nov 01, 2014
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
Posted on Feb 15, 2009
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Posted on Oct 03, 2009
May 11, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Aug 20, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Apr 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Apr 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
