good luck.
Testimonial: "thanks for the assistance ... I cannot boot anything up ... seems like I am stuck in safe mode ... I cannot do anything or type anything. Complete black screen and a movable mouse pointer. no command prompts nothing."
try a different keyboard and mouse for example if you are using a usb keyboard try another usb port then if nothing try another keyboard.
there are other things that you can still try or use. for example are you able to boot into the bios or cmos? that is done by hitting either delete button or sometimes fuction key F1 or
fuction key F2.
THE THE THING THAT YOU CAN DO IS HAVE A DIAG DONE ON THE COMPUTER AT A LOCAL COMPUTER SHOP. MAKE SURE YOU TELL THEM DIAG ONLY! IT NORMALLY RUNS BETWEEN 25 TO 35 DOLLARS. IF THEY SAY THAT IT IS TOAST LET THEM KEPT IT FOR THE COST AND GO BUY ANOTHER ONE.
SOURCE: eMachine T3120 keeps rebooting
The first time that you run the XP install, when the computer boots you will see "press any key to boot from cd". Do that, let Windows load it's files, etc., then it reboots by itself. When that happens and the computer is starting back up DO NOT respond to the "press any key to boot from cd". Just let it go and Windows will continue by itself. You are not the first or the last to have that problem.
If this does not solve you problem, please do not rate this post until other solutions have been explored, as hardware issues can cause the same problem(s), but try this first.
If you have the wrong disk, there isn't much recourse other than buying a new disk :-(
SOURCE: Windows XP operating system does not load.
You need to repair your windows xp installation.
Insert the xp install cd and power off - then power on your pc.
If the screen says "press any key to boot from cd" then do that.
It takes a while until you get to choose options.
Choose the repair previous installation option by pressing the R key when prompted.
Follow the instructions on the screen and you should be fine.
SOURCE: Windows Xp does not load Tried safe mode and all
send me an e-mail and i will help you obtain this software my e-mail is [email protected]
SOURCE: Machine shuts down when loading Windows
hi looks very confusing to me....fist u say pc is running the it turns off.....but also RUNNING....what is running/? is power to ur pc on or off/? as u also say u have to disconnect or pc from the power outlet....looking all this means to meu have a problem with ur powerpac and needs replacing or ur setting is wrong in power option
u can email me on [email protected] and i may be able to help u more if u give me more details
cheers
SOURCE: My Emachine T5010 reboots on Windows loading screen.
Before windows loads press F8 on the keyboard to get an advanced menu.
choose the option that says disable automatic restart on error and see what error you get.
Also try the Safe Mode option.
That click sounds like the harddrive is failing.
What started this problem? Does regular windows load ok? is the problem when you go into windows safe mode?
This problem started 4 days ago and then it died My mal now it will not boot ware detected unwanted software and it was quarantined
when I try to restart it shows nothing but mouse pointer
it's frozen there and I must pull the power cord to shut it off
I tried hirens boot disk ... no avail I have removed the ram etc .. no avail
I can go to bios and cmos no problem and do changes but to no avail
good if you can go into the bios the set your boot order to boot off the cd drive dirst. make sure the hbcd is in the cd rom drive. when the disk boots up if it says pres any key the hit the spacebar. once the menu comes up choose xp. Let me know. once your in I can help you if you like.
