Question about Kenmore Refrigerators
Where is the water filter on kenmore coldspot 106.9505712
Need to replace water filter on Kenmore Coldspot fridge, model number 106.9505712. I caan't find where it's located. Thanks.
  • Kenmore Master
  • 744 Answers
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Posted on Oct 25, 2014
6ya staff
SOURCE:
Michael Anderson
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
Anonymous
  • 750 Answers
SOURCE: How often do I change the water filter
Hello welcome,
here is the site to get and or print out your manual for your Kenmore Coldspot, Model # 106.74962400
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406138.pdf
Thank you , Huum
Please leave a solved rating before you sign off!
Posted on Dec 07, 2008
Anonymous
  • 195 Answers
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Anonymous
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
Anonymous
  • 572 Answers
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Posted on Feb 08, 2010
Kenmore coldspot 52582201- water filter part number
found it try here...
https://www.repairclinic.com/Shop-For-Parts/a4b6i183d605447/Model-10652582201-Kenmore-Refrigerator-Water-Filter-Parts
Jan 24, 2018 | Kenmore Refrigerators
Kenmore coldspot model: 106.74932400
Your fridge dose not have a water filter.
Aug 04, 2013 | Kenmore Refrigerators
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Feb 08, 2010 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
May 17, 2009 | Refrigerators
i cant even find a filter on your machine, if there is one, there will be a model number on the filter itself as well as re-order information.Once a yr , you shhould change
Dec 07, 2008 | Refrigerators
Refrigerators Logo
258 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
