THE TV WAS SWITCHED OFF AT NIGHT AND FAILED TO SWITCH ON THE FOLLOWING MORNING.
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
SOURCE: hitachi pd7200 42" plasma
Its a know fault with these sets - PDU's fail all time, look at avforums.co.uk
SOURCE: JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel In the scan boxes type 1 and 3 or what every you have your Satellite set to Then hit start scan The TV will come on reset to channel 3.
SOURCE: This may sound very strange, but in the middle of
Yes.
Please replace the Main board. It handles all the signal processing, and can cause automatic shutdowns and turn-ons.
SOURCE: I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
