Question about Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
Starts and runs few Minutes then dies have nothing plugged into it yet
    New Friend:
  • 58 Answers
Check fuel filter before tearing into carb. It's somuch easier.
Posted on Jan 11, 2015
    Sergeant:
  • 415 Answers
It sounds like it is starving for fuel. You probably need to rebuild the carb.
Posted on Oct 21, 2014
Anonymous
SOURCE:
Miller Legend welder. Onan engine starts and runs a few minutes then dies. Why won't it restart for 5 minutes?
Some engines have a low oil cutoff switch. If the oil level drops to a certain point it kills the engine. Your oil level may be close enough that after starting and running for a little bit the level drops enough to kill the motor. After sitting for awhile the level rises enough to allow the engine to run again check the level and add oil if necessary.
Hope this helps.
Bob
Oct 22, 2015 | Onan Starter for twin cylinder engine...
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Why does engine die right after starting, then you wait 10 minutes and starts and runs good.
check your crank and cam sensors...see if one is not plugged tight in
Jan 28, 2018 | 2005 Ford Focus
Why the engine starts, runs about 5 second, dies and then won't start, if you wait 10 minutes it starts and runs fine, this happens once every few weeks/months or twice in one day, no set pattern. hav
I saw what you replaced, didn't see any testing? What testing have you done? Make sure battery has a full charge?
When the problem is ongoing, have a helper crank it, while you check for spark at the plugs. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse. Any applicable trouble codes?
If you have the spider fuel system, that system is noted for problems.
Jan 28, 2018 | 1999 Chevrolet Blazer
Sputters after driving a few minutes, tries to stall out.
1st move is to ck the fuel PSI & emissions. Possible cooling system cause.Scan computer & check sensor readings & the emissions readings are the first moves. Check spark plugs, ignition spark etc. Good luck
Mar 25, 2017 | 1999 Volkswagen Cabrio
1996 ford f-250 starts runs a few minutes and then dies
will it start right back up? could be fuel filter or pump
Oct 20, 2012 | Chevrolet Cavalier Cars & Trucks
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E Logo
497 people viewed this question
Top Sigma Powers Inc Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Sigma Powers Inc Electrical Supply Expert? Answer questions, earn points and help others
