Ice maker and water ice on the door. Periodic water overflows drain pan and onto the floor.
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
SOURCE: Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Testimonial: "Many thanks for your help. The drain was blocked with ice as you suggested. "
SOURCE: Maytag side/side model MSD2754GR- Ice
Remove the back panal in the freezer compatment to reveal the evaporator. You will notice the drain pan frozen up with ice. pour hot water on it or blow hot air with a hair drier. If the fridge is turned off the ice will melt and clear the drain hole. When the ice is cleared the water will be alowed to flow out to the evaporating pan under the fridge. Be sure that the water runs freely out of the fridge and allow a few hours to dry. Good luck. Be careful not to damage the evaporating coils.
Testimonial: "allready tried that, still have same problem"
