Microsoft Windows Vista Home Premium DVD 66I-00010-os PC Desktop Logo
Lawy Lia Posted on Oct 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is different bitween 32 and 64 bit windows os
A
Anonymous
The difference ins in the way data is handled. A 32 bit unit can transfer 32 bits at one time and a 64 bit transfers 64 bits at a time, in a nutshell it just moves the data in larger chunks, but not necessarily faster! If you check the bios of your system it should tell you if its a 32 or 64 bit system. Most 64 bit units will run 32 bit software, but few 32 bit units will run 64 bit software.
bart NJ
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 06, 2015
bart NJ
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
646
Points
7
You should make sure any software you're trying to use with a 32-bit computer is NOT 64 bit software. I do not believe it's backwards compatible like that.
Robert Kilpin
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 50 Answers
  • Posted on Oct 19, 2014
Robert Kilpin
Expert
Level 2:
New Friend:
Cheetah:
Answers
50
Questions
0
Helped
16251
Points
130
32 bit edition will only run on a 32 bit machine and a 64 bit copy of windows will only run on a 64 bit machine.
Mikey
Level 3:
Top Expert:
  • Microsoft Master 6,904 Answers
 Mikey
Microsoft Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1622981
Points
26106
The more bits the quicker the processing!
Cant find driver for ethernet controller
The drivers would not be different. They would only be different if you were going from a 32-bit OS to a 64-bit OS....AND that isn't a doable 'upgrade' you'd have to clean-install it.
other than that, you have not provided any information, (PC Model, or Motherboard model,) for us to point you to a website that has your drivers.
Speedy eggbert does not play.
it's work on windows 7(32,64 bits)..an the password could broke whith 11111111111111111111111111111 at ending...;)
1helpful
2answers
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
1helpful
2answers
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
1helpful
Unable to use Wc3301 Gearhead Quick Cam on 64-Bit Windows.
If you have successfully run this cam with a different OS, try running it in Compatibility Mode
Right click on the webcam icon on your desktop or from 'All Programs' - select 'Properties'
Select Compatibility Mode
Use the dropbox to show the OS
Click OK
Restart your computer
2helpful
Difference between 32 bit & 64 bit OS ?
Here is a link from Microsoft that answers some general questions.
http://windowshelp.microsoft.com/Windows/en-US/help/41531554-d5ef-4f2c-8fb9-149bdc5c8a701033.mspx#EO
Bascially 64-bit processing can access more information at one time which will in essence be faster. 64-bit processing can access more RAM. 32-bit systems have a 4GB max. 64-bit systems have increased security benefits also. There are more links on the page above if you want to go deeper.
3helpful
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Title
hi,
the difference between workgroup and the domain is
workgroup is a peer to peer network, no centralised administration and security is less.
domain is a client/ server network, administration will be done by domain and is more secure.
ramana
sys admin
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
