Washer will not drain:
The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure to check the pump to be sure a small object like clothing or similar has not lodged itself inside of it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed.
Read more: HYPERLINK "http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/" l "ixzz3X2LbXMWJ" http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machine drain hose is where the water flows through to get the water out. If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the water from the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
The water pump belt (to drain out the water) may have broke or become frayed or loose. If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing the NO DRAIN issue and remove and replace if needed.
If the lid switch is not working as required it will cause your washer to not drain (and many other problems). This may be unlikely as a bad lid switch will usually cause your washer to also not agitate or spin. However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity
My advice is free cuz God is good!
