KitchenAid KSM150PS Artisan Series Stand Mixer Logo
A
Anonymous Posted on Oct 18, 2014
Kitchen aid stand mixer has sparks inside when on
Factory refurbished but visible sparks inside housing. Mixer works fine.
GE Fav
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Oct 20, 2014
GE Fav
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
12550
Points
31
Where do you see the visible sparking?? There are two places in the mixer where this could / should happen. One is at the brushes where they meet the commutator on the armature of the motor. I don't think you can see that place during operation unless you have the rear cover off and know just how and where to look down the tube of the motor head. The second place is at the rear of the machine at the copper contacts on the speed control switch. You can see in the machine during operation at this location. You should not be overly concerned about this...unless...you are seeing constant arcing, then you need a new speed control switch as the resistance (amount of metal to conduct the electric current) between the contacts is worn down. This will cause a constant arc and will eventually wear down and then freeze closed and ...Walla! the mixer will not work any more and it can short out the rest of the electrical in the mixer. So; if you are seeing short intermittent sparks at the rear of the machine , well no worries, if it is constant then replace the speed control switch if it is anywhere else it is an electrical short and that can be very dangerous indeed. Tell us where you are seeing the sparks...and we can FixYa.
  • Adam Fairless
    Adam Fairless Sep 15, 2018
    Hi, I am having this ame issue. I am geeting a litte bit confused however as when I seacrch of the part 'speed control switch' one one i find does not fit this 5KSM150 artisan model. I have found a Speed Control Phase Board is this the same thing?
5 Related Answers
A
Anonymous
  • Posted on Jan 19, 2007
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Anonymous
  • Posted on Jan 16, 2009
SOURCE: Kitchen aid mixer, voltage issue
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
Anonymous
  • Posted on Feb 21, 2009
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Anonymous
  • 478 Answers
  • Posted on Mar 11, 2009
SOURCE: my kitchen aid mixer makes a clicking sound when it is on
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Anonymous
  • Posted on Jul 30, 2009
SOURCE: Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Kitchen aid mixer ksm150ps won't turn on
See following video. Fast forward to 7:30 and it shows the on/off contact. Around a minute earlier it shows the the speed lever, spring, and link.
https://youtu.be/Pi8ufwlOtqU
The head of my Kitchen Aid stand mixer wiggles a lot when I us it
Put it upside down on a towel and tighten the hinge pin screw right up inside the pedestal. It's in the middle & retains the hinge pin.
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
1helpful
2answers
Hope this helps!
2answers
Kitchen Aid Classic mixer
There are 2 possibilities, the attachments are worn out where they go on the shaft, simply replacing them could fix it, the other is the shaft is worn out inside the planetary ( where it spins), if it moves allot, 1/8 " or more from side to side, the housing is probably worn, and the planetary needs to be replaced, easy job, don't know cost, a new mixer may be in order.
2answers
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
14helpful
5answers
Replacement parts for Wolfgang Puck stand up mixer
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page:
http://www.wpcookware.com/categories.asp?cat=32
Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
2helpful
Can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
