And the ice is coming out in sheets and clumps, not in individual pieces. It's like maybe the tray is getting too full and then it all sticks together. I can't figure out where the waxy looking piece goes. It looks like it is shaped like the underside of the ice cube tray.
The waxy piece has a clear plastic bracket, if its not connected, look
around your freezer. The waxy piece fits inside the bracket, and
attaches to the ice maker, just in front of the ice tray.
The
white wire fits inside the waxy piece. It is the thermostat that tells
the ice tray when to dump the ice.
This is impossible to feel
around for, so you will need to remove at least the bottom freezer
compartment as well as the ledge piece from just inside the freezer
door. If you are a relatively thin/small person, you can extend the top
tray fully outward, and slide underneath. Looking up at the ice maker,
the plastic bracket should have a little prong. This prong will attach
just behind the ice maker, with the thermostat facing the ice tray.
There is a schematic underneath or to the side of the ice maker, if it not there look on the manufacturers website to find where the piece goes it is most likely the cube former.
No schematic on side nor on website.
