May need new defrost heater. If so, that heater will read infinite ohms. A good heater will read 50 to 200 ohms. Change small inexpensive clip-on thermostat at same time. But don't worry about a little ice build-up if your temps are okay. Excessive ice build-up will be shown by your hearing a crunchy sound when you reach into the freezer to press your hand against its thin rear wall.
I’m happy to help further over the phone at https://www.6ya.com/expert/gramps_bab85ce284d72c1d
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
SOURCE: SAMSUNG RB215LASH fridge coil iceing up
first of all everyone needs to get off the idea the heater is not replaceable without breaking into the sealed system.. it is infact replaceable and seperate from the evap coil. you will have to order the whole assembly but the you seperate the front coil/heater from the holders and place it on your unit.. i think tiger direct sells the evap assembly and its around 70 dollars..
SOURCE: My 3 year old bottom frezer samsung fridge stoped
3 things defrost heater, defrost timer or defrost limit thermostat.
You can pull the cover inside the freezer exposing the evaporator coils,
look for the defrost heater at the bottom of the coils. Test for continuity.
Find the defrost limit thermostat, a 2" metal disc attached to the evap coil usually on the side towards the top has two wires going in and will have continuity only when it is cold. If those are good probably the defrost timer.
SOURCE: refrigerator side problem
most likely has a low refrigerant level due to a slow leak.you can call for service and have them add some gas to the system and it could be ok for a long time or if they can locate and repair the leak,it would solve the problem.call a few service companies and explain the problem.Ask how much each option would cost and decide if the frig is worth it
SOURCE: defrost not working heavy ice build up around
freezer not defrosting ice build up in back of freezer
