Mixer starts to make a grinding/clinking noise when the speed at the half mark. At lower speed does not make noise. also leaking grease.
SOURCE: Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two. This is caused by lack of lubricant or simply fatigue of the material of the gears. Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed. The money spent is well worth it because if done correctly will last another 12 years.
SOURCE: Question regarding KitchAid mixer, Model K45ss.
Yes this indeed does sound like you have a problem. There could be a couple different cause of this noise. If your main drive or worm gear has been damaged, it is likely to not run at all or jam up. So i think this is not the problem. There is however a codder pin located inside the transmission gears this can be seen by removing the upper housing of the unit, and then exposing the oil and gears. clear away the oil surrounding the gears, and save this grease for later. After this you should be able to visually see this codder pin AND the gears, rotate the gears while inspecting them and the pin. If the pin is slightly bent or broken this will make the grinding noise that your are talking about, while still operating and driving the unit. part number for the codder pin is 9705444. If however the noise is coming from the motor area this could indicate a worn or faulty motor bearing. This can cause the motor to operate on an angle and can cause a rubbing noise from the cooling fan or the winding of the motor itself rubbing on the mixer housing. Part number for the braket and bearing is 3180526. both are relatively cheap and easy to replace. If you find and fix the problem be sure to inspect or change the oil as this can often have metal chunks and other particles. Hope this Helps
Thanks
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
SOURCE: The mixer makes noise at
Hi,motor bearing usually worn out if you dont put grease on it.try also to check screws it might loosen up.Bearing might as well not contacted with the upper surface does it makes noise.Screw and bolts might as well loosen .Hope this helps.
SOURCE: Have a KS55 mixer that
A lot of things can happen to a piece of machinery after 4 years of idling time.
Dust, moisture, rust and dry hard Grease are just few of the problems. The
good news is it's not hard to put it back into service again. Obtain a copy
of the Repair Part List from Kitchenaid.com and start opening up the mixer.
Vacuum all dust inside, remove dirt and debris. Open up the Transmission
Housing and scoop out of the old grease. Use fresh Kitchenaid Food Grade
Grease for all gears including the Agitator (part of the Planetary Assembly) and
you are good to go.
