Wiring harness for john deere 1530 tractor
Try this link. It has lots of wiring diagrams including your tractor.
Yahoo Image Search Results Page
SOURCE: I don't have spark on my john deere x324 tractor.
X 300 series had 2 known problems.One is the delay module under dash has been an issue scince model came out,it's the first thing I replace when I have one that comes in with no spark.The second issue is the coil grounding/kill wires have a diode in them and when one diode goes bad the engine will only have spark to the strongest coil.If you lost spark to both coils and machine still cranks I would replace the delay module under center of dash.
Testimonial: "This was very helpful as Guru hit the problem on the head and I was able to get out of my driveway.Thanks Guru"
SOURCE: adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
SOURCE: i have a john deer tractor i need to know the
Hello. go to this link, select the series you have and find your number. http://www.oldengine.org/members/murphy/jd_garden_tractor_serial.htm
SOURCE: can u tell me what size of hydrolic pump is fitted
There are 3 pumps that were used on this model.
Part number is:
AR103035
alternate / sub PN: AL70641
This 8 piston 11.3 CM3 pump is rebuildable at a fraction of the cost of a new or re-manufactured pump.
http://cheaptractorparts.com/store/product5697.html
There are 6 kits for this pump depending on what has failed on the pump.
Kits
AL71015
AL71016
AL71017
AL71018
AL71019
AL71020
The John Deere Parts catalog can be found here using you model number:
http://jdpc.deere.com
Pump PN: AR103036 23CM3=1.4 CU.IN
and
Pump PN: AR97872 40CM3=2.4 CU.IN
All of these pumps can be repaired. It just takes a talented and patient person to do the repairs with kit parts in hand.
Thanks for choosing Fixya,
Kelly
