how do i set the gov. on a craftsman LT1000 riding mower the motor model is 917-271652 ?
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
SOURCE: how much oil does it
The best way to do this is to check that the unit is full of oil. Then measure what comes out when you drain it. Put this amount back in and you should read about a pint less than you need. That is because that is what is in the filter that you changed when you drained the oil. You are going to change the filter, right?
Fine tune the top up and you are good to go.
