I have a Maytag French Door Bottom Freezer / Refrigerator. Model MFI2568AEW. I changed the water filter today and 10 seconds after installing the new filter it started making a very loud noise like a machine gun when I ran the water. I put the old filter back on and it happened again. I finally put the bypass cap on and it stopped. Any suggestions?
Sounds like water hammer, has the water supply got it's own shut-off valve behind the fridge or in the basement ? Try shutting the valve then open it just a little. Perhaps the water supply was opened fully after installing the new filter.
Testimonial: "I shut off the water at the fridge water hose and let it sit for 10 minutes while i drained the air out of it. I installed a filter and turned on the water 50%. It worked fine for about one gallon and then the noise started again. I took the filter out, replaced the cap and turned the water up to 100%. No noise - but no filter either. I'm stumped."
SOURCE: my Maytag refrig. water dispenser & ice maker has ceased to work
there is a "control lockout" feature on the newer dispensors, ( not controlled by you(there is a control lockout feature)but I dont thinkn this is your issue.. the control lockout has somehow sensed a flood of water and for safety reasons has shut off the dispensor, the only way to reset this is to reset the control module, . You can either call for an autorized servicer to come reset, or if you feel up to it there sould be a trouble shooting/tech sheet taped to the underneath of unit, in the front right corner(behind hte kickplate)..
SOURCE: Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
SOURCE: I have a Maytag model MFI2568AES french door
don't think you need a new unit . and most of use like the service . the filter does not prevent the ice maker from working . but the water valve does and the tempt in freezer must be 15 deg or lower . ck your fan inside and underneath. both muts be going . hope this helps mm .. and ck with another service theat will be helpfull. mm
Did you bleed the air out of lines. You can do this by running about a half gallon through the dispenser
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Tried shutting off the water at the inlet for the water hose; cleared the air from the line and put a filter in. I opened up the line halfway and it worked for about 1 gallon then the hammering started again. I took the filter back out and installed the relay cap and turned the water on full. No hammering. I'm stumped.
