I do not want to receive email messages from this hotmail user. I want to block his messages
Most of the Gmail users are having a question on how to block someone on Gmail. However, to block someone on its platform is quite so easy. To do this, just press left-click of your mouse on the 3 dots shown at the top right of the email and scroll down to select on block option. Hurray!
Here is a link to the info you seek
Block unwanted emails - Gmail Help
SOURCE: NOT ABLE TO SEND EMAIL, OR ADD CONTACTS, NO CHAT BURTTON APPEARS
email/s sometimes has a virus and others threats mailed to us unaware even thou the source is reliable where the email service affected their good service, your problem is within the scope of google.com just click the google help and relay your problem to them and they have the technical procedure to fix their service problem.
SOURCE: i have a Motorola Droid smartphone that i set up
Hello there!
Please make sure that you have subscribe a data plan from your Network Provider to be able to have the added feature of push email.
You may consult your network provider for the proper settings.
Regards,
fossildude
contact gmail technical support
Windows Live Hotmail allows users to view attachments within a Web browser or save them to the system's hard drive.
If Hotmail can't open an attachment, the problem lies with an incompatible file format or Hotmail's automatic blocking service.
You may need new software installed on your computer IE: adobe . direct x , zip for opening unfamiliar formats, while blocked files are permanently inaccessible from within Hotmail.
Accessing these files requires action by the sender or forwarding the file to a different email client.
Incompatible File Format
Occasionally a sender may attach a file that simply doesn't work with any software you have installed on the system.
Attempting to open the attachment will result in a "Windows cannot open this file" message or similar error display.
Many programs use very specific file formats that don't operate with most other software, such as Photoshop's PSD image files or Microsoft PowerPoint's PPT files.
Ask the sender to convert the file to a more widely compatible format, or install the appropriate software on the system to open the attachment.
Blocked Attachments
Hotmail blocks attachments it believes may contain unsafe or otherwise malicious code.
This includes any and all executable file types, including MSI, EXE, HTML, STC and COM files, along with many others.
Attachments blocked in this way result in a "Windows Live Hotmail has blocked some attachments" message when viewing the email.
While this service does block many real threats to system security, Hotmail may occasionally deny access to an item from a trusted sender.
Unfortunately, these files become permanently inaccessible once blocked by Hotmail, and accessing them requires using a workaround outside the Hotmail application.
Only attempt to access attachments you trust as safe.
Forward Workaround
While Hotmail cannot open blocked attachments, it allows users to forward the message with the blocked file still attached.
Send the file to a different email client, and open the attachment using that account instead.
Note other clients may have different security measures, but some will still block access to executable files and other potentially harmful data.
Compression Workaround
Ask the sender to package the attachment into a ZIP, RAR or other compressed file format before attaching.
Hotmail will not block any file type located inside a compressed archive.
Both Windows and OS X can create compressed ZIP files, and free utilities such as Zipeg and 7-Zip can create many other types of archives as well.
Some email clients, such as Gmail, will not allow users to send some file formats, even when packaged into an archive file.
Hope this helps
