Refrigerators Logo
A
Anonymous Posted on Oct 14, 2014
U line refrigerator won't turn on. outlet is OK
Refrigerator won't turn on. no power but outlet is OK
Harry Plunkett
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Oct 15, 2014
Harry Plunkett
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
3726
Points
Check circuit breaker/fuse in back of refrigerator usually located in the rear of the frige behind the panel where the electrical cord disappears.
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
When you push start button nothing happens
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
1helpful
Craig tv plugged in stand by light won't come on and tv won't play
It could be. But make sure the power outlet is ok. Please try on a different power outlet.
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
My water knozzle drips water all the time. The ice maker was jammed and in an attempt to fix it now the water knozzle drips. How do you turn off the water?
There is not an on off switch, and if you turn the house water line off, you won't have water to the ice maker. So if you want to turn only the water off to the fresh water dispenser, you will need to disconnect and then cap the water inlet valve for the water dispenser. To find it, just follow the house water line to where it connects to the water valve of the refrigerator. There will be two outlets on the valve (ice maker and fresh water) disconnect the fresh water line and cap it. You can purchase a cap from any hardware store.
2answers
No power to refrigator check plq and it is hot Light in sisde dont even work
It could be a loose connection where the power cord is connected to the refrigerator inside or a bad power cord. If that doesn't solve the problem you may consider calling a repair person.
Good Luck,
GilShultz
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
