I dont know my cell phone nokia c3 pin code please tell me
Try this link:
https://vpsfix.com/3146/fix-nokia-pin-blocked-enter-puk-code/amp/
Hi. What kind of pin code are you asking for your Nokia C3? If it is a security pin code, it must be 12345 or 0000. If it is a network unlock pin code, you can visit Unlock-Zone.com and get it at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Nokia C3 with a NOT ACCEPTED SIM Card.
2 - Your phone should display 'SIM Restricted'.
3 - Press OK.
4 - Using the full qwerty keyboard, compose the code as #pw+CODE+1# and press OK.
Note :For Nokia C3 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Press OK.
4 - Using the full qwerty keyboard, compose the code as #pw+CODE+7# and press OK.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Nokia C3 is locked to.
The CODE you need to enter is the unique unlock code for your Nokia C3
SOURCE: starting pin forgot for nokia 5310 Xpress music
The default PIN code of a Nokia mobile is 0000 (four zero).
Try with this. You may also refer the User Guide of the phone for the PIN code.
NOTE: If you Enter a incorrect PIN code three times then your SIM card will be block and then you require a PUK code to unlock SIM and Phone.
You will get the PUK code from your SIM card service provider (mobile network provider).
Good Luck!!!!!!!!!!!!!!!!!!!!!
SOURCE: how can i format my nokia c3 phone? i cant access
you cant format a mobile you can only reset it to factory but listening to your fault i would say your keypad is broken
SOURCE: nokia c101 cell phone free unlock code book
gimme the IMEI code I will give you the unlock code
