Eacon Far-Infrared Sauna Cabin - 3 Person Logo
n
natasha zeidner Posted on Oct 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the back heaters to turn on, I would like to find a manual for my sauna
Please contact me @ 310-592-7809
Ewaldoh
Level 2:
Champion:
  • Expert 220 Answers
  • Posted on Oct 13, 2014
Ewaldoh
Expert
Level 2:
Champion:
Answers
220
Questions
0
Helped
43532
Points
400
Natasha, honey, I don't know your make/model; but go to their web site and download it.
1helpful
3answers
Where is the reset button on the BS-36UFF on demand toyotomi water heater
The Toyotomi OM122DW on-demand water heater typically doesn't have a physical reset button like some traditional tank-style water heaters. If you're experiencing issues with your water heater, there might be a few troubleshooting steps you can take:
  1. Power Cycling: Turn off the power to the water heater by switching off the circuit breaker or unplugging it if it's a plug-in unit. Leave it off for a few minutes and then turn it back on. This action can sometimes reset the system and resolve minor issues.
  2. Check for Error Codes or Indications: If your Toyotomi water heater has a digital display, it might show error codes or indications for any problems it's encountering. Consult the user manual for the OM122DW to understand what these codes mean and how to address them.
  3. Inspect Gas Supply: Ensure that the gas supply to the water heater is uninterrupted and that the gas valve is fully open. If there are any issues with the gas supply, it might affect the water heater's performance.
  4. Check Water Supply: Ensure that the water supply to the unit is adequate and that there are no blockages in the pipes leading to the water heater.
  5. Contact Support: If you've tried these steps and the issue persists, it might be best to contact Toyotomi's customer support or a certified technician. They can provide specific guidance or schedule a service visit to diagnose and fix any issues with your water heater.
Regarding a physical reset button specifically labeled as such, it's important to consult the user manual as the location and method for resetting the unit can vary between different models and versions of the Toyotomi water heaters. If you don't have the manual, you might be able to find it online on Toyotomi's official website or by contacting their customer support.
Heat is not working on hvac package unit
The unit you state is a Sauna heater/humidifier. I do not understand how or why it is connected to a heating ventalting air conditioning (HVAC) system, please explain.
The water heater stays on vacation mode - how do we reset this?
Please add a comment and say which type, and model water heater you have.
Look at label on side of tank.
If you have electronic control, please describe the control.
This information will let expert access manual and possibly write best solution for your situation.
If you have tankless water heater, read manual, or contact Rheem or qualified service technician.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
We have an E 13 code on our Steamist keypad.
1) Sample manual for Steamist does not show E13 error code
http://www.steamist.com/Downloads/pdf1/554-G.pdf
2) Another sample manual does not show error codes
http://www.steamist.com/Downloads/pdf2/572.pdf
3) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician who can make repairs.
http://www.steamist.com/contact.htm
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on Steamist or any do-it-yourself project.
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
I replaced a 15 year old Rheem 40 gallon electric water heater with the same - a Rheem heater. After I replaced the old one, I was surprised that there was hardly any sediment build-up at the bottom of the...
These are interior metals, similar like rock used in a sauna, to help keep water hot longer. Here is somethings to check out.
Hello, dave
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Timer will not turn water heater ON at set time, has to be done manually. However, it will turn water heater OFF at set time.
If this is new installation, check wiring. Hot and Load wires might be reversed.
Check that ON OFF trippers are both attached to yellow dial.
http://waterheatertimer.org/How-to-wire-WH40.html
If timer worked fine before, and started missing recently, then tripper pins probably worn out.
Trippers contact mechanical lever, and push lever on-and-off.
Trippers are softer metal and designed to wear out before lever.
If lever is worn out, timer needs to be replaced, but try new trippers first.
Buy trippers at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How WH40 timer works:
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-and-off, manual override lever also snaps back and forth with audible clicking sound.
Using q-tip, add touch of white grease to lever where trippers contact.
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
The water heater turns off and does not come back on except if turned on manually.
If this water heater is a gas heater and you have to manually turn up the thermostat each time to get the burner to come back on it could be gas control thermostat.
Top Eacon Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Eacon Water Heater Expert? Answer questions, earn points and help others
