Blinks three times with a small noise but won't come on.
Sounds like the color wheel, if you see bulb light up when it blinks or see a tainted picture. Usually.it has a loud squealing noise with it.I'm guessing its the lamp-bulb. Try bulb first, because the color wheel is very expensive. You can install the bulb yourself very easy too install-can find how to install on YouTube. You can find a bulb on eBay for around 50 dollars.__Warning-............do this at your own risk== and have knowledge about electronics and electricity, and have TV unplugged
Hello
there are caps on the SMPS module usually associated with that
the tops will be bulged up . id look at the values and check a local electronics part supplier or a local Tv repairman for these caps .
Shop Jimmy should have them also on line .
or Matt Electronics sells these cap's
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
SOURCE: tv blinks abut three times and goes off!!
i had a tv do that b4 and someone told me it might be the bulbs in the tv and you might have to get them replaced but it could be something else i suggest you take it to a tv repair shop and have them look at it to really be sure
SOURCE: RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
SOURCE: My RCA D52W14 wont turn on it makes a weird noise
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
