SOURCE: Whirlpool washer f30 code
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
SOURCE: LG WM-2277HW Front Load Washer E1 error
You may have a bad valve. The multi valve is cold and the single is hot. You can go into test mode and check them out to see if how the are fuctioning. Caution must be used. DO NOT GO INTO TO TEST MODE WITH CLOTHES IN UNIT AS IT WILL NOT BALANCE OUT FIRST AND WILL BOUNCE ALL OVER, AGAIN DO NOT DO THIS.
here is how to acces the test mode
With the unit off
Press and hold 'spin speed' and 'soil level'
turn the power on
press the start button to advance
once the tub will rotate clockwise
2nd time low spin speed
3rd high spin
4th inlet valve prewash
5th inlet main wash
6th hot water
7th bleach
8th tumble counter clockwise
9 heater comes on for 3 seconds
10 circulation pump
11 drain
12 power off
again do not attempt this with clothes in the unit.
if the valves don't activate fully than it is a bad valve and it has to be replaced.
Sgt 48
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: LG front load washer OE error. cleaned filter need
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
SOURCE: I have a samsung wf203anw
Posting a problem with your POS Samsung washer here is a waste of time! UII currently have the same problem a lot are having with this not draining nd code and I AM NOT going to pay for a tech to tell me that I have to have a guy come in to take my washer apart. I will do it myself!
