SOURCE: soap doesn't go out of dispenser
Make sure you are using a liquid or powder detergent made for front loading machines and has the HE symbol on the front. Also use warm water not cold some detergents may not dissolve completly
SOURCE: LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
SOURCE: soap dispenser not working
It sounds like the water valve has a clogged filter. Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve. Clean out the filter with toothbrush. Reinstall and everything should be ok.
SOURCE: LG 2077 CW-has IE code issue as well as soap dispensing problems
IE is an inlet error indicating that the machine has not filled up to the correct water level within 10 minutes. Could be a bad inlet valve, low water pressure or a problem with the inlet hoses (do not use anti flood hoses with these machines, use only the included fill hoses).
It sounds like all of your problems lie with the water fill. If the dispenser compartments do not get water added to them then the soap, bleach, and/or softener will not dispense properly. Then it will still be present and may dispense on the next load instead.
It is also VERY important that you use an HE (high efficiency) detergent and the correct amount (2-3 tablespoons per load). Otherwise you could end up with oversudsing issues which can also keep the bleach from dispensing properly.
Also make sure to not use GEL bleach, GEL detergent or GEL softener as they are too heavy and will not dispense properly. If all of these recommendations do not help then there is a definite issue with the incoming water supply from the inlet valves (especially if the IE errors continue). In that case you will need a technician to check the inlet valves inside the machine.
Hope this helps, please rate my solution.
SOURCE: water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
