Freezers Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
GE TBX21ji Refrigerator/Freezer Factory Ice maker Quit making Ice. The Freezer Temp is set to the Coldest. You can remove the front cover and Manually turn the large gear and it will start to try and turn out the Ice Cubes, but the only way it will succeed is if you pour a small glass of hot water over the Ice Reservoir. The it will dump out perfect sized cubes and refill the Water... This has been going on for 24 Hours. Thanks for any help. Jerry 423-886-5002
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Jul 04, 2009
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751535
Points
5690
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
  • Anonymous Apr 17, 2013
    How about when the ice maker is not filling up with water; is there a way to test the ice maker (such as with a (DMM) to check if the problem is with IT, or within the fridge itself (water not being able to get to the ice maker, etc). Any suggestions would be helpful.
Ice maker quit making ice
Does the food in the freezer freeze solid? Do you see any ice buildup on the back wall?
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 • GE Freezers
1helpful
2answers
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 • Freezers
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 • Freezers
1helpful
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 • GE Freezers
Ice maker quit working on brand new unit
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
cxxcxcv
2answers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 • Freezers
Freezer doesn't defrost
in the freezer there and evaporator and there and element look like a glass pipe that what make the ice melt it probably broken remove the inner panel of the freezer lock for broken glass thats our problem cheers
Jan 14, 2008 • Freezers
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
