My new samsung top loading washer wa50F9A8D SW/A2 model is shrinking my cotton clothes when on tap water choice. Does samsung put any warm water in at factory setting on tap water? I know cold setting does put warm water in at one point to "disolve" the HE soap.
SOURCE: Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
SOURCE: not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
SOURCE: samsung front loading washer, New, model WF218AN
IF IT IS NEW YOU SHOULD CALL FOR SERVICE. SAMSUNG HAS A 1 YEAR WARRENTY. IF YOU ARE USING HE SOAP AND NOT TOO MUCH YOU SHOULD CALL FOR SERVICE
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: Hi there, I have a Samsung top loader and have
Surely you are in a better position to work this out than us! Try ising a hose with a rubber cup connection to fot to your tap.Perhaps even boild up a large container of hot water and carry it to the machine!
Thanks for using FIXYA
SOURCE: Samsung WF330ANW front load washer--was just
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
