I ACCIDENTLY LEFT MY LAPTOP UNPLUGED ALL NIGHT AND WHEN I PLUGED IT BACK IN AND INITAILIZED CUBASE THER WAS NO SOUND. THIS HAS HAPPENED BEFORE AND I CLOSE THE PROGRAM AND REBOOT THE COMPUTER. THIS ALWAYS WORKS EXCEPT THIS LAST TIME I LOST ALL PREVIOUS DATA JUST ON MY CUBASE PROGRAM. IT WENT BACK TO FACTORY DEFAULT. CAN I GET MY MUSIC BACK? I HAVE WINDOWS 8 HP
SOURCE: sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
SOURCE: HP laptop speakers went out, fairly new
Hi kimberly,
If your laptop is still under warranty then this is something they have to repair for you. It sounds like a hardware error, not sure about the actual fault but two speakers burnt is weird. (Especially if you keep the volume near 60-70% of the max volume)
Still if the laptop is out of warranty then dissasemblying is required. The information required are all give to the Service manual of th DV6000 provided from HP itself along with the part list and coding of the new set of speakers you need.
The process is not hard actually for this model. It can be done fairly easy. (in other laptop a complete disassembly is required which is very tough task)
The manual you will need is the one below. (Simply left click)
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
At page 146 you will see how the speakers are removed. Also follow the instruction on the quoted previous sections.
The part number of the speakers is 431447-001 and it is mentioned at the same page.
The part costs around 5$ used from Ebay :) If you dont believe me check it out yourself :)
http://cgi.ebay.com/HP-DV6000-SERIES-SPEAKERS-431447-001_W0QQitemZ180230305257QQihZ008QQcategoryZ16145QQcmdZViewItemQQ_trksidZp1713.m153.l1262
Many regards and I hope you can get your precious laptop working again as a charm :)
EngineerGR
SOURCE: Troubleshooting(i think)
it's an application error try to disable it during startup by clicking start, select run, in the dialog box type "msconfig" (without the qoute) in the Systems Confiuration Utility window select the startup button located at the upper right portion. clear the check box that has an entry of 'atbroker' then click apply/ok then restart your pc. hope this helps.
SOURCE: reboot my hp laptop
Hold and press the power button down ( and dont let go ) for at least 10 seconds or untill laptop shuts down and you can reboot by powering it back up by pressing power again. If it still shows access denied after you rebooted then more than likely you need a password.
