This is driving me nuts. It looks as though they are assembled to the leveling linkages before the frame is built and spot welded into the groove they are supposed to slide up and down. They cant been tapped out because there isn't enough metal on the frame to support hitting it with a punch.
Http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%203952817.pdf
Testimonial: "This isn't a part of initial setup which your reply refers to. Im trying to replace worn rear legs on the washer which are visible in the image at the top of page 3."
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
SOURCE: Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
