Hello Mike,
It means that most likely that your Defrost Heater (DH) is not working and one of the following items could be bad;
Er dH
Sensor did not get over 40 F
Faulty fuse, heater, control board
Controller assembly, defrost heater, relay on control board
Here is the whole list for your refrigerator; Kenmore Bottom Freezer Refrigerator Error Codes for 795 Models Sears...
Your manual should have a troubleshooting section. Er would mean an error, and the 2 would indicate the problem area.. You could also call the manufacturer at a number usually on the nameplate. You may also Google the manufactures name/Er2 and see what comes up. Good luck. Try to find out soon so the error doesn't increase with time.
Does it just show "er" or does it have "er" and two more characters? The "er" means there is some sort of problem, and the other two characters will indicate what kind of problem. If it's just showing "er" alone, I not sure what that means.
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right: Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService. Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service. For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService Er FS - Freezer Sensor Error Er rS - Refrigerator Sensor Error Er ds - Defrost Sensor Error Er dH - Defrost Heater Error Er CF - Cooling Motor Error Er CO - Communications Error
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
