SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you
need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
teyet
SOURCE: My Bissell PowerEase carpet cleaner
Unlatch the cannister according to the directions, you will see a meatal latch, unhook it slide off Power nozzle, rinse it off, pull lint, hair off brushes, reassemble
