Question edited to add FULL make model (what it is).
Category moved from Washing Machines to Ryobi Trimmer.
Replace the spark plug. Strip and clean the carburetor. Replace the fuel with fresh. But hang on though, the RY40002 is electric and runs with a 40 volt battery, so no spark plug and carburetor! :>D Replace the battery, lubricate everything from the motor to the head. Check the motor with nothing attached to it. The carbon brushes may need replacing or its bearings need greasing.
Includes (1) RY40002 40V Power Head and (1) RY15523A Expand-It Trimmer Attachment · Compatible with All Ryobi 40V Lithium-Ion Batteries (Sold Separately) ...
US$119.90 · ‎Out of stock
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
I have a Ryobi Model RY28040 straight shaft line trimmer. In my case I replaced the complete String Head Assembly that includes the String Head Housing, Spring, and Spool and the string still did not advance. I then discovered that the bolt in the Spool Retainer cap (the red cap that attaches the spool to the shaft) was fused and not moving. The bolt needs to be loose inside the cap in order to allow the spool to move in and out by the spring. I loosened the bolt and fastened the spool back onto the shaft. Fired it up and bumped it a few times and the line began to advance. Turns out I probably only needed to replace the Spool Retainer rather than the String Head Assembly.
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM
Head)
Use 2.4mm monofilament string. Use original
manufacturer's replacement string for best performance.
n Stop the engine and disconnect the spark plug wire.
n Cut one piece of string approximately 7.6m in length.
n Rotate knob on string head until line on knob aligns
with arrows on top of string head.
n Insert one end of string into eyelet located on the
side of the string head and push until string comes
out through eyelet on the other side. Continue to
push string through the string head until the middle
section of the string is inside the string head and
string outside the string head is evenly divided on
each side.
n Rotate the knob counterclockwise on the string head
to wind the string. Wind the string until approximately
20cm remains protruding from the string head.
INSTALLING STRING IN PRO CUT II STRING
HEAD
Use monofilament string between 2.4 mm and 2.7 mm
diameter. Use original manufacturer's replacement string
n Gather two of the pre-cut lengths of trimmer line provided
or cut two pieces of trimmer line, in 28 cm lengths.
n Insert the strings into the slots located on the sides of
the string head. String should be pushed in until
approximately 2 cm protrudes from the holes on the
top of the string head.
n Remove old string by pulling it from the holes located
on the top of the string head.
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
