I have a Craftsman with a Kohler por 17 hp engine. I've replace the carb.,fuel filter, air filter, spartplug. The mower starts great, runs for 5-10 min. then starts cutting out and then quits. After a few min. it will start and only runs for 1-2 min. and does the same. Help!
I have GT6500 26HP runs for awhile begins miss firing runs on one cylinder, must be running hot ( fuel may be vaporizing ) removed the Hood and it runs fine.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
This is not a solution, I have a 18.5 hp, with the same problem, still have not found a solution or a fix. This is what I have done to mine, cleaned air filter, carb, new plug set at .30, changed oil and filter, removed coil ( armature-magneto) cleaned it and re set at proper setting , 30 thousands. checked spark when hot, removed and cleaned gas tank, replaced fuel line and filter, also, renewed muffler and connection gaskets,checked spark plug wire, and all over sparks, o.k. I have run out of ideas, any thing you fine, let me know..
Don.
It sounds like you have water in your fuel..have you drained the fuel tank and checked for water?
