My Kenmore Elite front load washer washes just fine. On the rinse cycle it didn't drain! Clean out the filter and finally replaced the pump motor. Now it still comes up with the "OE" code. It won't spin on the rinse cycle!Any thoughts? need help!
SOURCE: The door of the Kenmore Elite 4.3 cu. ft. Front Load Steam Washer won't open
Ouch. Well I believe cll is child lid lock or something to that effect is engaged. You will have to find something to manually turn the locking gear or if you have a manual figure out the watts/amps and use some type of power adapter similar to that to jump the lid lock to open. Turn it off and back on and it should begin working again. But either the door lock, the door close sensor, or the main board are faulty.
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display suds and then
F02. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
