Can't locate timer on Kenmore bottom mount refrigerator model 596 6997 3011
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
SOURCE: kenmore bottom freezer refrigerator model
it may not have a timer but a aditive defrost control . most common with newer model .. its located in the fresh food side just behind the thempt contro knob and its a pc board .. . . do ck your heater first and the defrost terminator as thes two parts ore more common to cause your freeze up .. mm
SOURCE: my kenmore bottom mount refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: Can't find the defrost timer on my Kenmore refrigerator 596 series
If you get the complete model number which is located inside the refrigerator on a tag either on the upper left or right wall or the roof inside and then go to partselect.com you will get an illustrated blow out and you'll be able to see exactly where every part is
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: How can I manually set the defrost timer on my Kenmore 596 series refrigerator?
If the defrost timer is a control board, then you won't be able to manually set it, get the model number from inside the refrigerator and go to www.partselect.com and there you will be able to get a full illustrated blow out of the machine and locate the part your looking for
