Question about Amana Refrigerators
My ice maker on an Amana Freezer is locked
Cannot unlock the ice maker
Anonymous
SOURCE:
Anonymous
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
Anonymous
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    projdoc
    jasbo
    • 2239 Answers
    SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
    5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
    Posted on Aug 28, 2009
    Sheikhtijani
    Shehu Pro
    • 1284 Answers
    SOURCE: my ice maker quit making ice.
    Hi, If your ice maker has stopped making ice then you need to check these things.
    The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
    Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
    The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
    Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
    Take care
    Posted on Jul 23, 2010
    BoschDrippin
    SOURCE: How do I unlock the ice-maker panel?
    Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
    Posted on Aug 15, 2010
    Ice maker stopped working on bottom freezer amana. Is there a reset button?
    There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
    Replacement parts can be purchased at any of the following web sites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    partsselect.com
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    These will help.
    Thanks,.
    Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
    Ice maker doesn't work amana tj18kL
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Sep 25, 2010 | Amana ATB1832AR Top Freezer Refrigerator
    My ice maker has stopped working. The only change we made was to turn the temp. in the freezer down to #4.
    heatman101
    dj35
    Sep 21, 2010 | Amana ABB1927DE Bottom Freezer...
    Ice maker did not produce ice, then it started to
    heatman101
    Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
    Jun 28, 2010 | Bosch Evolution 800 B20CS80SNS Stainless...
    Ice maker arm in freezer
    On most automatic ice makers the arm is in the up position to make ice, but check with the manufacture to make sure
    Jul 20, 2009 | Amana ABB1927DE Bottom Freezer...
    Ice maker freexes ice together
    maybe too much water going in to the ice maker
    Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Amana fridge ice maker not working
    need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
    Jun 21, 2009 | Amana Refrigerators
    Ice maker drips water
    In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
    Nov 02, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Refrigerators Logo
    133 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Thomas F. Schneider
    Marvin
    Marvin
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
