No one will tell you exactly. There could be several variants, you have to disassemble the device and look at it. Maybe there is something wrong with the circuit board, or with the contacts, or the laser transmitter has burned out and needs to be replaced.
There are 2 small screws holding the rotating head motor in place. Likely you just need to loosen these screws, and adjust the motor position and retighten.
If you have the standard RL-H3C then there are 3 buttons. Starting from the left there is the "height alert" then "manual" then "Power".
Height alert is a function that after the laser levels and spins monitors the position of the laser. If the laser moves more then a tiny amount then the height alert function is tripped, and the laser flashes it's lights and stops spinning (or spins slowly) to let you know the base line position of the laser has changed. Pressing the height alert button twice shuts this mode off.
Manual mode means after the laser is leveled, it completely ignores the level vials. You can turn the laser any way you want to and it will always spin and not cause any errors.
Power is self explanatory.
If it's a RL-H3CS then it has two arrow buttons, that when in manual mode, allot one axis of the laser to be manually adjusted up and down to do a manual slope.
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series.
Take this to a survey/laser repair shop, preferably one that does not charge for estimates.. The laser diodes on the RL-H3C is not serviceable. It requires the lens barrel assembly (or telescope tube unit, i don't remember what they call it in these). It's unreasonably expensive, and will likely be a write off. It may however be the main circuit board, but likely not. Be prepared to replace this unit.
