Model: Carina
SOURCE: Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
SOURCE: How do you thread the Elna Carina?
thought I had a manual with an image of this but can't find it.
But pretty simple.
Place thread onto one of the spool pins at the back right, and pull thread across to the left and around the white blob on top of the machine head then back to the right to the little thread eyelet, down through this and down to the thread guide taking thread around it from the right and back up on the left side, back up and through the thread take up lever, then down again catching behidn the little thread guide, then to needle bar thread guide, then to needle eye.
ALWAYS HOLD THE two threads firmly behind the pressure foot when you start sewing - Really important.
Always wind and insert the bobbin with the holes on top, smooth side downwards. Place bobbin into bobbin holder and take thread take towards you and into the tension spring groove, pressing down on the thread with your finger until you hear it click into the tension spring. pull back the other way to check it is in there, if it comes out, do it again.
Bobbin will rotate anticlockwise when you pull the thread.
THen put needle plate cover down and draw bottom thread to the top using flywheel or the needle up/down button on these lovely machines.
Hope this helps, if not post again and I'll dig out images from my SU manual.
SOURCE: I need an instruction manual for the Elna Carina
There is a sewing guide available free here for the SU which is very similar to the Carina
http://www.arizonaexpressionz.com/elna_instruction_manuals/SU_air_electronic.pdf
but not an instruction Manual.
The SU, Carina, 500 and Jubilee all came with two books, instruction manual and sewing guide.
