Need to get rid of E 15 on top. No lights on burners. Model EW30ES65GBE
It is likely you may have used self-clean feature at some stage before this happened. The error is something to do with oven overheating. This is common when you use self-clean. The solution may be to reset the thermal fuse.
See this thread on internet for possible solution. Hope it helps.
F15 Code on Electrolux EW30DS65GS5 The Kitchen Appliance Repair Forum
SOURCE: Looking for Cause of Fault Code on GE Range top JP939
Have SAME EXACT issue - F113 on Left burner. Indicator says HOT and not even on. Called a service company (NOT GE SERVICE). They said the Element Radiant is no good and must be replaced. Part is quoted as $323.98 !!! What a rip off from GE !
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
SOURCE: I have a Garland commercial electric range.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: When I attempt to light
u can solve this problem by cleaning off the igniters. first of all unplug it from the power. Then take a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. then go ahead and scrap it and brushed clean the mating surface where the spark travels. then vacuumed up the mess. your burners all worked great after this.
or
Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on.
Thank you for your post, friend!
I see that you are having difficulty with your induction range element on your Electrolux range. From the information you have provided it is taking longer for items to heat up on that burner. You may need to have that burner replaced and I would recommend having a professional technician come out to perform any repairs. This is not a simple DIY job it may require a possible disassembly of your range. I hope this information has been helpful. -Matt
From my understanding your Electrolux range is displaying an error code of "E15". An "E15" code stands for the ESEC self-test failed. This might be an issue with your ESEC (Electronic Surface Element Control) board or ESEC-UIB (User Interface Board). Before seeking any assistance with a professional technician I would advise you to perform a reset on your range. You can perform a reset by disconnecting power from your range for roughly ten minutes. If that does not help resolve your current issue I would suggest consulting with a technician for repairs. Hopefully this information is helpful. -Matt
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
