SOURCE: Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
SOURCE: Borken LCD Screen on 37" Vizio HDTV
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
SOURCE: black shadow on screen vizio 37 in lcd hdtv
There is a part inside
the TV that needs to be replaced. If the TV is under warranty—whether
the original warranty from the manufacture or an extended warranty
purchased with the TV—call the company providing the warranty
coverage and they will arrange to have your TV repaired at little, or
no cost to you.
Since some brands will
pay for your repair even if you're out of warranty, especially if
they've heard of your problem before and it's a known issue. You
should always contact the manufacture first for your full range of
options. If they're willing to fix the TV for free, or at a reduced
cost to you, let them!
If the TV is out of
warranty, and you have the experience and you know what you're doing,
you can fix the TV yourself. Purchase the service manual from the
manufacture to get started. However, if you've never done anything
like this type of repair before and you don't know where to start, I
suggest speaking with an experienced TV repair-person.
If you decide to pay for
out of warranty repair by a professional repair shop, the total cost
will likely be a minimum of $200 parts and labor. However, be warned
that the cost could be considerably higher.
I hope I've provided you
useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you today!
Please post a
comment if you need additional assistance so that I can help you
further.
Testimonial: "it was helpful thank you do you happen to know what this part is?"
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
