Mold smell coming from inside bottom of drum
Hello friend, thanks for your post!
I understand that you have a mold smell developing inside of your Frigidaire washer. I would normally recommend using a clean wash cycle with either one cup of bleach or one pouch of Tide Washing Machine Cleaner. If you do not have a clean wash cycle on your washer you could also use hot water and a regular cycle with a cup of bleach to clean out your washer.
You should also check over your gasket to assure there is no mold buildup, if you do locate mold inside of your gasket you can use bleach to help get rid of any residue. I hope this information is helpful. -Matt
SOURCE: Egg smell and mold
Every manufacturer should be included in that lawsuit!
Let's put the blame exactly where it belongs and keep it there until manufacturers clean up their act!
What in the world are we thinking when we allow ourselves to be forced
to jump through these ridiculous hoops just do do laundry!?
I am furious and it is over something as stupid as a washing machine! A WASHING MACHINE!!!!
New government regulations for new water efficiency washing machines
has my family’s clothing smelling like a stinking, rancid, moldy
basement! This is absolutely absurd! I have been told to change
laundry detergent, run hot bleach water through my washer and, get
this; my washing machine is 1 year old and my clothes smell filthy!!!
The mold and mildew from these nasty machines have wreaked havoc
through skin rashes and allergies in my children!
I paid $1,000.000 for this da*ned washing machine and THIS is what is
being sold to the public under the disguise of efficiency!!?? I have
been on the phone about this problem. I have, over the past 3
months, with a technician on the phone, been instructed to do the
following:
*Make sure I use high efficiency detergent THAT will fix my problem.
Wrong.
*Cleaned the lint trap (..that is stupidly behind a metal access plate
that you have to use a screwdriver to remove screws to get to it EVERY
TIME) and THAT will fix my problem.
Wrong!
*Cleaned the water hoses; THAT will fix my problem.
Wrong!
*Cleaned the gasket around the door. THAT will fix my problem
Wrong!
*Cleaned the tub with bleach water. THAT will fix my problem.
WRONG!
*REMOVED the hoses and cleaned the pump. THAT will fix my problem.
WRONG AGAIN!
*Take the pump out entirely and clean all inlet, outlets and hoses. THAT will fix my problem.
WRONG! WRONG!! WRONG!!!
NONE of this fixed my problem of filthy, wet, stinking, rancid clothing
that has endangered my family's health! I even washed my children's
clothing out by hand in the bathtub and put them in the washer just to
rinse and spin and they STILL smelled horrific.
Finally, at the end of my rope, I returned to the appliance store from
which I purchased this machine and they have told me that they cannot
accept a return. They will not accept a return and I have to deal
directly with GE. I HAVE dealt with GE up until the final straw when I
they told me I needed a new pump, but so sorry, your warranty JUST
expired 3 days ago!!!
Furthermore, my pump was fine. I did NOT need a new pump and have now
been told that I cannot return the new, unused pump that cost me
another $183.00. I have now been told that this is a problem with ALL
front loading washing machines and I should do the following:
*First, run a full complete wash cycle on hottest setting containing Bleach – * Note: wash cycle takes 1 hour and 20 minutes
*Next, run a full wash cycle on hottest setting using high efficiency laundry detergent for another 1 hour and 20 minutes
*Next, run a full wash cycle on hottest setting using Cascade automatic
dish washing detergent for an ADDITIONAL 1 hour and 20 minutes
*Next, using Bleach water, wipe down entire interior of washing machine
*Next, using clean white cloth, wipe entire interior of washing machine dry
*Next, leave door ajar to air out machine
*Finally, I have now been informed that I cannot use fabric softener in
the machine even though there is a fabric softener dispenser right in
the machine because the new front loading machines cannot handle fabric
softener!!
Furthermore, I was told that this is new technology and since it is so
new, no one really knew these kinds of problems were going to manifest
themselves and I just need to try to work with these problems because
it is not the manufacturers fault but the GOVERNMENT’S fault! Sorry.
Are you kidding me??
Now I have a $1000.00 piece of junk that the appliance companies are
pawning off on unsuspecting consumers and hiding their horrible designs
by blaming the government.
So, now this is what I want!
I want the legislature to force manufacturers to properly inform the
public of these problems and those who did NOT inform consumers of
these issues, COMPENSATE their customers for the $$$$$ it has cost us
and the misery and frustration caused by THEIR neglect by NOT informing
the consumers of these issues. I want this to be retroactive BACK to at
least the year 2005. Furthermore, I want compensated for the cost of
buying a top loading washing machine in an effort to keep our families
away from the mold and mildew and filthy mess this has caused! Finally,
I want manufacturers to own up to the fact that they disregarded the
health and safety of consumers in their efforts to profit as much as
possible while touting efficiency.
Now I have heard that they have a new 'product' they can sell to us to
inhibit the stench of mold and mildew. This is absolutely unacceptable!
This is outrageous and we need to speak out about this and make sure our voices are heard!
SOURCE: Frigidaire Front load washer mold
LEAVING DOOR OPEN BETWEEN USES ALLOWS WASHER TO BREATHE. BEING A CLOSED SYSTEM, IT'S KIND OF LIKE PUTTING A TUPPERWARE LID ON A BOWL WITH RESIDUE AND MOISTURE INSIDE AND LETTING IT GROW.
SOURCE: Smell coming from inside washing machine. Not musty.
This is a fairly common problem that often arises when the majority of washes are done with cold water.
Do what is called a maintenance wash where you set the machine to run with hot water and maximum fill of water. Add one half cup of baking soda and let it run through it's entire cycle with absolutely no clothes in it.
After it completes its full cycle check for that bad odor. If it is fully gone wonderful. If it is half as bad do a second maintenance wash.
If the maintenance wash doesnt seem to help at alll get back to me and I will make another recommendation.
SOURCE: smell coming from insie washing machine
This is usually caused by mostly using low temperature washes. The detergent manufacurers don't tell you, but low temperatures don't kill the bacteria present on most clothes, so they breed and and multiply in nice warm moist washing mashines. The cure is to do a "maintenance wash" every so often, which is the hottest wash the machine can do, and this will kill the bacteria. Also adding washing soda to this wash will help to freshen it up.
SOURCE: I can not seem to get rid of the mold smell from
I have a front loader and hated the machine for the very same reasons. A one shot fix does not exist but rather requires ongoing treatment (they don't tell you that when you buy the washer though).
Star by getting rid of the existing smell. There are products designed specifically for this problem. One such is "Affresh" but there are others. Most are available at stores that sell the machines and like everything else, on the internet too. Use as directed and once the smell is gone, maintain by using the steps below.
Firstly - discard all non-HE detergents. I know the "regular" detergents are cheaper than the HE counterparts, but these machines are designed for the low-suds types; the regular types leave a soapy residue because the machine doesn't use nearly as much water as your old top loader. So give them to your friends with top loaders instead of using them in your front loader.
Next, run a small load, with bleach and hot water only - no clothes as the last load for the day.
Thirdly, leave the door(s) open on the days not used. This includes any top door for detergents / softeners along with the main front door of the machine between washes. It need not be left wide open - but open enough to allow air in to help dry the interior.
Fourth, wipe down the interior after the last load of the day. Pay particular attention to the rubber seal between the drum and the door jamb of the machine.
Fifth, stop using fabric softener in the washer. Use a fabric softener dryer sheet instead. Limiting the products added to the washer to just bleach & HE detergents is best.
Sixth, use the washer cleaning product (Affresh etc.) as needed as a preventative step or to head off problems if / when they just begin to become noticeable.
If you follow all of these steps - the offending odors can be eliminated and prevented.
I hope this was very helpful and good luck!
