Cycling Logo
A
Anonymous Posted on Sep 25, 2014
How do you fix your broken down wheels in the middle of nowhere but you do have your emrgency kit and fixing kit ?
How do you connect the parts to a bicycle if it has broken down or your wheels,gears and brakes have fallen apart with no service accompaning you ?
Jesus Robles
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 30, 2014
Jesus Robles
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
2114
Points
24
I learned by experience. When something breaks down, I learn to fix it for when it breaks down the next time. On a bike, the parts most likely to break down are a flat tire and a broken chain. Carrying a flat repair kit and a multi tool to fix a broken chain is feasible. You can break a wheel spoke. This you can't fix in the field but you can compensate by learning which spokes to loosen/tighten adjacent the broken one to get you home/shop. You can break a brake or derailleur cable. A spare cable is light and easy to carry but it is very time consuming to replace in the field. Depending on how far you are from home, it may be easier to ride home with a broken cable. Preventive maintenance is the best way to avoid broken cables and/or chains - replace them every 3 years or so, depending on usage and wear/tear. Other broken parts, you will have to assess in the field. You may have to walk home or call a friend to pick you up.
5 Related Answers
Anonymous
  • Posted on Nov 02, 2008
SOURCE: Bicycle Rear Wheel Problem
You may have buckled your wheel if its a spoked type ! If you have buy a spoke key and tighten the spokes opposite the buckle .............ie if the buckle goes over to the left stop wheel and tighten spoke that lie on the right of the rim ..........it fairly easy if your rim is not to badly damaged..... you will have to keep on tinkering to true the wheel up.......ps also check your spoke are tight before starting as i have seen spokes just loosen for no reason.......hope this helps.
Anonymous
  • 71 Answers
  • Posted on Jun 11, 2009
SOURCE: rear bicycle wheel won't turn. Brakes are siezed.
Find the arm that hold the cable. Loosen it to the desired tension.please comment if it does not work for you! I can help! Good Luck!
Anonymous
  • 98 Answers
  • Posted on Jun 19, 2009
SOURCE: I have a DBS bicycle and the rear wheel hub is
You might need to have your wheel replaced. If you take it to a shop they can use your old gears and tire. This well help cut the price. What is the nature of the problem?
Michial Gueffroy
  • 1140 Answers
  • Posted on Aug 28, 2009
SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
Anonymous
  • 8546 Answers
  • Posted on Jul 21, 2010
SOURCE: i have a Shimano Nexus 7 Speed (SG-7C18) Internal
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Nexus/CoasterHub/SI-7C26C-EN_v1_m56577569830605809.pdf
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/SG/EV-SG-7C18-2396C_v1_m56577569830702946.pdf
You'll probably need some special tools - or take it to a bike shop and let them deal with it.
Fuel leak up in front by fire wall.Bad smell inside car.What possible lines need fixed?
I had this exact problem. I had a leak where the fuel line connects to the engine. A plastic interface part was broken and not sealing. I replaced the fuel lines (from tank to engine). The assembly comes only with both send and return lines and connectors. Later, I found out that a kit to replace only the interface part exists. You cut the send line and slip the replacement part over the line and connect it up. My repair was over $450.00. The repair kit costs about $25.00. I've not seen one. Fix this at once. The car is dangerous to drive.
4helpful
2answers
Steering wheel turns freely but does not move wheels
Follow the steering column down to the gearbox. You will see a "knuckle" that the arm goes into. It may possibly have a "donut" that looks like it's made of a tire - if not it will go into a metal flange that transfers movement to the gearbox.this is where you need to look closely and have a helper move the steering wheel as you are looking. The donut or the flange has broken and you will need to replace the part there.
My 99 passat tie rod that connects to the wheel broke off (front passenger side) Would you explain what needs to be done the parts, etc......Does the car have an axle that is 2 parts connected in the...
you are looking for a tierod end this is the part that broke. take the nut off at the spindle(wheel side) and tap it out with a hammer. now for the part that is still on the inner tierod(middle strait bar) just unscrew the tie rod end (broken part) witch a pipe wrench and install the new one. ***do not loosen the nut behind the tierod end on the inner tierod or you will have to get a wheel alighnment***
1helpful
2answers
I have a hp md5820n TV NOISE is coming from the middle front of T
99% chance your color wheel is broken. You will have trouble finding any replacement parts (difficult, but maybe not impossible). HP will charge almost as much as a low end LCD TV of that size to fix it, assuming they even can do so, as I do not believe they have many replacement parts left for these TVs (and are simply cannabalizing old ones, the same as most people who are attempting to fix these TVs). Check on the AVS Forum, there are several threads related to these TVs.
I have a kenmore 80 series washer and it won't fill up some times
It sounds like a siphon issue so nothing should be broken.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
3helpful
John Deere Snowblower - wheel won't spin
yes 2 solutions. the sheer pins have got broken down on that auger that wont spin, they go through the middle bar. easy fix. about 2 dollar.
The other thing is. The drive belt located directly in the middle of the machine has a plastic cover over it has slipped off or is broken.
THis is a little more tricky as you split the machine taking off the collection cage usually to fix. I charge 89 dollars in my shop to do these.
Its not hard if you pay attention to where you need to take off the parts.
2004 clunking noise thru steering!
Its probably the intermediate steering shaft. The shaft where it goes thru the firewall is known for clunking on these trucks. GM makes a lube kit to fix the noise. I don't have the part number handy, but the parts guy at the local dealer will know what you are looking for.
Good Luck
2answers
I have a Graco Stroller serial number 7525GCKU (1 think that it is a Quattro Tour Deluxe) and one of the front wheels has come off. The piece of plastic that connects between the metal leg and the wheel...
I know this sounds a bit cheap, but superglue/adhesive is too brittle to make a good fix. Especially seeing as the unit cracked unevenly.
I took the unit off the arm of the pushchair by pushing the little metal clip in at the bottom and pulling it down.
The rest of the unit which was still inside the wheel needs a pair of tweak nose pliars and a flat head screwdriver (and a lot of patience). You need to use the pliars to grab the unit in the middle of the little circle, then use the flat head screwdriver to push in once side of the expanding clip in the middle.
Once you have both broken parts, hold them together in the correct place and wrap A LOT of cellotape around the two bits. Then clup both bits back on and hey presto, it works!!
Just taking it for a "road test" so to speak now, but it was an easy fix. You just need to be careful when removing the parts that you don't break them beyond recognition!
I tried to pull the two parts apart with my hands after and to be fair, the fix is probably stronger than the original flimsy bit of plastic.
If anyone wants any help on how to fix it (pics or more of a descriptoin of how to get this bits off) drop me an email at [email protected].
Top Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Cycling Expert? Answer questions, earn points and help others
